RCU Forums - View Single Post - PLEASE HELP!!!
Old 01-30-2006 | 01:09 PM
kdheath
Default RE: PLEASE HELP!!!
Did you check the metal lines in the tank for cracks? They can crack and cause weird problems. Go over the engine for loose bolts-a loose backplate can also cause weird symptoms. Fresh fuel and a fresh glow plug can't hurt, either. And it could be a little lean and/or not quite broken in, if it's new.
