RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 01-30-2006 | 01:46 PM
  #2010
batfalcon's Avatar
batfalcon
Default RE: E-FLIGHT BLADE CP
ORIGINAL: zooland1
The mixer arm from e-flight is a bell mixer, not bell-hiller. The CP2 parts are bell-hiller. Parts list is back two or three pages. I just got the CP2 parts but haven't tried them yet. Futura has them and loves it. He's the reason I ordered them. Since the blade comes stock with a hiller head maybe the upgrade makes it full bell-hiller, don't know. I haven't read anything anywhere about anybody who tried the bell grips. They've been available for quite a while, just not under the e-flight name.
First I want to thank you for your post. It was helpful. Never thought that I should count the pinion's teeth. I did, after your post and you know what? It HAD ONLY 8 !!!!!!. Since I own the FP as well, some day I may exchanged the motors without noticing. I had another one (spare) with 10T which I put on and as I see it now, everything is back to normal. Thank God. It does make sence. I had only 8T so I had to power all the trim up and stick more than 3/4 in order to gain the proper rpm to lift it. So hearing the motor screaming, I added more pitch to reduce rpm and gain lift. Now things are ok. Thanks again.
And now to the bell/hiller mix. From the videos I posted, what do you range my upgrade. Bell mixer or Bell hiller? I don't exactly know either the difference or where the names come from.
BTW, Where can I find an 11T pinion? Is anyone here that has one for spare, and willing to send it over Greece?
