RCU Forums - View Single Post - Turbine oils/difference?
Old 01-30-2006 | 01:53 PM
Miniflyer
Default RE: Turbine oils/difference?
There are many widely spread opinions about this, but the fact is: if it's full synthetic oil it will work, even if it's intended for automotive use.
In fact there has been a long term test of running a turbine on diesel fuel without any oil here in germany. The bearings did not care much for it, the running surfaces held up to the tests. (I'm not saying you should do it, just that it will work WITH DIESEL).
You can spend hours of discussion on what oil to use, and wether to use 3,6% or 3,9%....but in the end you'll be fine with whatever you do.
Just my experiences
Hank
