ORIGINAL: TREADSTONE22
ORIGINAL: rcdriver22
This side of the big pond using aviation turbine oil is not recommended by GTBA and BMFA because of the health risks and accumulated effects.
WHAT...
...thou pullest our legs.....where on earth did this come from..
....you been down the Pub..?.....
Tar Baby..
...500, 2380, MBJII are all something like 97% the same, its only the manufacturers base oil addative package that diferentiates them slightly.....by the time we've diluted them down further...well, the difference is'nt even worth typing about... Personally, having spent several years in the oil reaserch buisiness i wouldnt really use the Steam Turbine or 2 stroke oils which have totally different lubrication properties completley...just my threepennybits worf...
_____________________________
We shall require a substantialy new way of thinking if mankind is to survive.
Albert Einstien.
is this ka ka...
.... I was only proping the bar up and chatting to the wenches.
Paul
RCdriver
...Christ man, this is 1,000,000 times more hazardous to your health than baithing in turbine oil daily...
..I think the organophosphates mentioned was a useful substance within Suddams Weapons??
Paul
RCdriver
..was he in the pub with you when he told you this...
EASYTIGER Date 1/29/2006 4:39:41 PM
Well, maybe his IS putting out 14 pounds, I dunno! Test it! Have NOT measured my own.
I do remember Sean running yours and saying "it runs like a little engine should!" Starts and runs, but was it putting out the stated thrust...or even CLOSE to it? Big difference, depending on what plane you have.
B1Driver Date 1/29/2006 4:22:54 PM
Paul you might not care, but I sure as hell do... Try pushing an 18lb plane with a 9lb turbine when its supposed to do 14lb. The results arnt very pretty no matter how you look at it. Hook us up with picture of this plane your putting it in. I'd love to see what goes 311kph on 5lbs of thrust.
rcdriver22 Date 1/29/2006 11:14:34 AM
WHAT... ...thou pullest our legs.....where on earth did this come from.. ....you been down the Pub..?.....
Hey Treadstone
How did you know I was in the pub?? I was only proping the bar up and chatting to the wenches.
__________________________________________________ __________________
GTBA Code of practice Appendix 2
Turbine Oils containing Organophosphates
Special oils, designed for full size gas turbine operation, may contain hazardous chemicals such as organophosphates. Given suitable precautions to avoid skin contact and the breathing of vapours these oils can be used safely. However non-toxic alternatives such as TCW-3 two stroke oil are available and have been used successfully in model gas turbines. Many operators may prefer to use these oils because of their environmentally friendlier properties. If you are in any doubt as to the suitability of these oils for you particular engine you are advised to consult the designer or manufacturer.
What do I know? only that full size crew avoid ALL direct skin contact and never stand down wind (this is also more to do turbine bits coming loose). If you read the COSH notes for the turbine oil "Control of Substances Hazardous to Health Regulations" - COSSH... then it is pretty clear don't put the children, pets or fish ponds down wind. I think the organophosphates mentioned was a useful substance within Suddams Weapons?? Lastly its just a good reason why less oil or TCW3 is better all round.
Gone flying
Paul
RCdriver
ot..
