ORIGINAL: avalanche wolf
Wel I have a new problem now.
I got my new parts in the mail today [ cnc alum swashplate , and main rotor / tail heat sinks ]
Problem I am having now is the amount of power that is needed to lift off. I am at full power and 1/2 power on the trim and i am only about 2 inches off the ground. Also now the helo jerks up and down like a sticky colective ( checking to see if everything is installed correctly. )
Any ideas ???
It sounds like you positioned the swashplate too high and have less positive pitch than you had with the original swashplate. With the throttle stick all the way down, the blades should be level with the flybar (0 pitch). Crank the adjusters on all three servo arms until you achieve this. Here is a link with great info on setting up the rotors:
http://www.lenlutz.com/pages/blade_tuning.html
Hope this helps, the above link helped me get things tuned after I rebuilt everything after a serious crunch....
Doug
