RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 01-30-2006 | 10:47 PM
  #2020
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
ORIGINAL: avalanche wolf
Problem I am having now is the amount of power that is needed to lift off. I am at full power and 1/2 power on the trim and i am only about 2 inches off the ground. Also now the helo jerks up and down like a sticky colective ( checking to see if everything is installed correctly. )
Any ideas ???
Check the pinion, you want 10 or 11t with stock or 2s lipo, 8 or 9t with 3s---and what dj said. You need to make sure the links are loose too. Gently squeeze them on the ball with needle nose pliers to loosen them. The balls on the alum swash are slightly oversize.
