RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 01-31-2006 | 01:20 AM
  #2024
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
Ok. I think I got it. The alum swash is thicker than the stock one. The specs are to have 1/2" clearance from the top of the shaft to the top of the swash. You need to change that to 7/16" so the swash doesn't bottom out on the collar. You won't be using 100% negative so allow the extra clearance on positive.
