RE: Tower Trainer 40 Nose Gear
Make sure coil spring is not scraping bottom of fuselage . Nose gear control arm will stick out about 30 degrees from firewall. A flat spot is needed to keep steering arm from twisting on shaft . OEM are a little weak a stronger replacement is a good idea.
