I didnt make any adjustments at all to the swashplate. I just pulled the stock off and put the new one on. I will also try to lossen the ball conectors to check the stiffness...
I did notice there are 4 ball links on the upper swashplate . Does it matter which 2 i use ??
The aluminum swashplate is thicker than the stock one. I had to make adjustments to the servo control rods to get mine setup properly.
Doug
