RCU Forums - View Single Post - parkzone cub question
Old 01-31-2006 | 10:48 AM
x030399
Default RE: parkzone cub question
Zeroseven, I got a Cub two weeks ago and taught myself to fly on it. It's very forgiving and easy, PROVIDED you fly in no wind. I got a FB Scout for Xmas, then bought a Hobbyzone Micro Ultrix for $30, with shipping. I have a private pilot's license, but zero RC experience. Understanding the fundamentals of flight, I believe, will make it MUCH easier to learn to fly RC. That said, I took the Scout out early Jan to fly in 15mph winds, having never flown an RC before....bad idea. It lasted 5 minutes before running away 1,500 feet downwind and augering in on one wing, cartwheeling along the ground, destroying the wings, literally SHATTERING the whole tail sections, and snapping the carbon fiber boom. When I reached the sight of the carnage, the little bits of foam that once made up the vtail were already blowing away in the wind, and about the only thing that survived was the rubber nose bumper.
It was fun while it lasted, but I didn’t really gain any RC piloting skills from that experience. Next, the Ultrix arrived in the mail and I took it out, and over two days of playing, actually got it so that I can consistently fly it without crashing, even in 10mph winds, (although it hardly moves when going upwind.) Finally, the Cub arrived two weeks ago, and my first flight was in wind around 8mph. I learned from the Ultrix that you should only use very quick “blips” of control when you’re learning, otherwise you’re very likely to stall or do a wingover. I also learned that you should get TONS of altitude before making any turns b/c even if you screw up and start a spin or stall, just let off all throttle, straighten the controls, and the plane will usually recover almost by itself, if you have a lot of altitude.
So my first flight, I let the cub go right on up to about 100’, reduced throttle to 1/2, then started my turns. I was surprised b/c I feel the Cub is easier to control than the 2 channel planes b/c you’re able to use down elevator to beat into the wind. With the 2 channel planes, you’re at the mercy of the wind and just have to keep porpoising to go upwind. I made several successful circuits and decided to bring her down. Unfortunately, when I got about 10’ off the ground and coming in at 1/3 throttle for a landing, a gust tipped one wing up, and she went straight into the ground. The plastic cowl shattered, battery box shattered, prop shaft bent and plastic gear shattered, the positive lead broke off the motor, and the nose was slightly rumpled, but surprisingly, the prop survived. When I ordered the Cub, I also ordered replacement prop drive shafts, hearing how easily they’re ruined. I epoxied in two pieces of foam, one against the firewall, and one in front of the Rx, making a snug space to put the battery. The gearbox went back together no problem, and I was able to solder the motor lead back on and was good to go (couldn’t glue the cowl back together, so it looks ugly till the new one arrives.)
In the meantime, I also bought an Aerobird Challenger, and I took that and the re-built Cub out yesterday. The day was a perfect 60F and ZERO wind. Flew the ugly Cub first and it was rock-solid stable and straight. Took it to 100’ and went around in circles for 5 minutes, landed with no nose-over, flew again till the battery was out and had another safe landing. I tried the Challenger next, not knowing what to expect, and was surprised to find that it’s as easy and stable as the Cub. I’m not ready to attempt aerobatics yet, so I just leave both on ½ throttle after climbing, and do gentle turns with the stock control throws dialed in. They both just putt putt around the sky like a dream, and seem like the easiest things in the world to fly. Then the wind picked up. By this time, I had the Cub back in the air with a ¾ charged battery, and suddenly noticed it acting a little erratic and difficult to control. I first thought the battery was going, but then I realized the wind picked up to 5mph with little gusts of about 8mph. I decided not to tempt fate, and brought the Cub in for a nice landing and called it a day. Next time, I'm going to remove the jumper that makes the Cub give it some up elevator when you turn the rudder. It definitely does help when you first start out, but now it's starting to get annoying when it does that, and I'd like to have full control myself.
Bottom line, if you have no wind at all, the Cub is a cinch to fly even for a beginner. Use small blips of control, keep throttle as low as possible after you reach altitude (you’ll go slower, making it easier to correct mistakes), and I also noticed that my Cub is easier to control with almost full down elevator trim. Otherwise it wants to keep nosing up a tad. If you lose control, and it's obvious that you're going to crash, try to remember to cut throttle to zero before you hit, b/c this might help save the prop and gearbox. Also, I recommend taking the cowl off until you’ve gotten the knack and are very comfortable flying. It may be ugly, but you’ll save yourself a few replacement cowls. Also, if you don’t already, order yourself a couple of extra prop shafts with plastic gear, and propellers. Sorry for the long post, but I wanted to share the lessons I learned, so that others will have as much success teaching themselves to fly, as me! Good luck!
