RE: Gyro options...
ATV is adjustable Travel Volume, or End Points or EPA End Point Adjust.
Basically the gain is set by changing the travel volume or throw on the gear channel.
The piro rate is controlled by the atv or travel volume on the rudder channel.
The travel limit of the servo itself is set on the gyro using a pot.
