RCU Forums - View Single Post - Engine right thrust-why?
Thread
01-31-2006 | 05:06 PM
18
P-40 DRIVER
Apr 2005
1,623
1 Post
Cedar Park, TX
RE: Engine right thrust-why?
If you are referring to torque as the force causing the plane to rotate counterclockwise if the prop is rotating clockwise, it is a force although I really don't know if right thrust would do anything to help compensate for it although it is so minimal, it may not be an issue. I realize my jargan is not completely right but I do understand how it works. I have also heard the forces related as torque but by my above statement you could see how that would be very confusing due to most peoples understanding of what torque is. Thats why I refer to it as P-factor although not technically correct. Right thrust help make plane go down straight down runway and track good through air to put it in an easy to understand way.
Reply
Like
P-40 DRIVER
View Public Profile
Send a private message to P-40 DRIVER
Find More Posts by P-40 DRIVER
View iTrader Profile
