If you have the D&B/Reichmuth ignition the engine is timed at about 18 degrees BTDC..Time it where it belongs, at 28 BTDC...Be careful starting it, there is no spark retard...You engine WILL run like it should if timed correctly...Been there
C&H has a hub keyed for the correct timing...[8D]
