RE: E-FLIGHT BLADE CP
crash-you will still need a separate esc for the motor. The 2-in-1 is for using a brushed TR with a brushless main motor and separate gyro. Hopefully you thought to order a single conversion crystal for the blade. Your TX will likely come with a dual conversion which won't work in the 2-in-1. I didn't think of it either and my LHS doesn't carry singles. So I had to wait for a separate ordered crystal before I could use the radio. That is unless you really thought ahead and ordered the TX in the same channel as your bird and that way it "will" work.
Hondulan-I know, I read the same thing you did about converting the RX to positive shift. I have no idea where I read it. I suggest doing a specific search in google for "converting e-flight 4-in-1 to JR" or something like that. Keep trying different searches and you should hit it somewhere. It seems to me you had to hack into the electronics and jumper something. Sorry, I have futaba so I didn't persue it, just remember reading it.
