RE: Alpha 60 RTF 4 stroke conversion
That is correct Bruce.....the movement is restricted even when not connected to the servo. In fact , if I can get these pics uploaded to you, you will see an obvious difference in the Hinge area of both of these wings.....I just didn't want to take a sharp knife to it so quickly without knowing how the hinge is assembled....I am sure your comment on too much CA or epoxy is true....It appears to be some sort of white looking material---epoxy of some sort.....I will try to figure out what happen to the upload of the pictures.....They were attached and went somewhere!!.....Thanks for the recommendation and help Bruce......I did not intend to change the thread concerning this matter but really did not know where else to go to ask.....so Thanks again..
Steve
