RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 02-01-2006 | 04:24 PM
  #326
mtracy
Default RE: Bdavison's E-flite Blade Assembly
At this step, it appears important to have the servo arms level. I assume that means straight out, perpendicular to the main shaft. Well, one of mine is not, however the swashplate is level (perp. to the main shaft). It appears that from the factory the one arm was off, but the control arm is adjusted to level the swash plate.
Any comments? Thanks,
