RCU Forums - View Single Post - Digital servos
Old 02-01-2006 | 10:40 PM
Infinite Gundam
Default RE: Digital servos
Overlocking as in full left or right steer results in the steering tie-rods pressed up tightly against the suspension arms, this means you have more servo travel than you need, and you will need EPA's to reduce the servo travel range. My 5955TG (when used with stock radio) overlocked so badly that it significantly flexed the chassis at the mounting area.
