did it 3d well with that motor? What are landings like? Did you have the cg a tad nosew heavy?
What I have done with the cowl is drill holes and insert the yellow flex tubing into the fuselage, with thin CA.then the screws go into the tubing. It king of works like a drilled hole in the wall and inserting those green things..
with the Nylon bolts, can you give me a link to which ones I should get please? I also noticed the plane vibrates a fair bit, I mean I have checked everything, balanced all and vibrating still. Must be the structure of the plane.
Cheers and thanks for your help
