RCU Forums - View Single Post - screaming servos ?
Old 02-02-2006 | 03:01 AM
JohnW's Avatar
JohnW
Default RE: screaming servos ?
"Because there is load on them." - yup, that pretty much sums it up. Other sources of load/resistance would be linkage drag, friction in the actual linkage connections (like pin in hole), and the weight of the surface can also load the servo. It is not really possible to totally eliminate all of this, but as mentioned in the previous post, it is important to eliminate any surface or linkage binding.
