RE: Adjusting OS .46 FXI
Low end = idle RPM. Sorry for the confusion.
Instead of going all the way back to factory settings, just reverse the last couple of changes you made if you can recall them. Probably need to make the idle more rich at this point.
Actually -best advice would be to get with an experienced engine tuner at the field if you can.
