RCU Forums - View Single Post - carbs, props, and plugs
Old 02-02-2006 | 08:50 AM
ljones5000
Default RE: carbs, props, and plugs
Yeah, I have C-H ignition and have had no problems with it other than the prop blast blowing the spark plug wire off. Finally, I put a plastic tie on it and fixed that problem.
Thanks for your input.
By the way, I read someplace about some engine that you could plug into the ignition system and get rpm readout. And after a flight you could see the maximum rpm the engine reached during the flight. Anybody familiar with that? It sounds really interesting, maybe I just dreamed it.
Larry
