Magic plane cleaning spray.
Hi troyp,I use window cleaner mostly,if the build up is a lot I'll use alcohol,only trouble I've had with alcohol is that it can work under the covering and decals,loosing the edges,tons of different cleaners will work and some people make there own secret brew,409 cleaner might be what you're asking about.
