RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 02-02-2006 | 09:34 AM
  #328
1LO64
Default RE: Bdavison's E-flite Blade Assembly
I don't see the benefit of having them perfectly level simply because the swashplate sits off it's access to compensate for wash anyways. Also, extreme flying rarely happens with the Blade where the max throws of the servos are required....I trim & fly!! If you start tinkering with things that you have no idea about you're only gonna get yourself in over your head and it'll fly horrible, IF it even gets off the ground.
