RCU Forums - View Single Post - pull-pull rudder better?
Old 02-02-2006 | 09:17 PM
shd3920
Default RE: pull-pull rudder better?
How do you set up a pull-pull system? Don't you need to cut a pushrod exit on both sides of the fuselage to exit both rods (or wires???) to the control surface? If you need to, and both sides are cut out for, say, the elevator where do you cut the double exits for the rudder?
Please explain, graphics would help.
