RE: Midwest Extra 300xs Build
A few more updates,
After sanding the leading and trailing edges flush with the sheeting,
1.) Marked the hinge locations on both aileron and wing and step drilled to the right size
2.) Beveled the leading and trailing edges
3.) Cut recesses for the hinge point in the edges
4.) Hinged the aileron to the wing to check for clearance and hinge gap.
5.) Full hinge gap
