RCU Forums - View Single Post - Midwest Extra 300xs Build
Old 02-02-2006 | 10:14 PM
  #177
Digger44's Avatar
Digger44
Default RE: Midwest Extra 300xs Build
Had to start thinking about joining the wing and a place to set it while it dries. Well the only spot I have big enough that would support the entire wing flat on the top side, with the exception of the floor, is my pool table. Can't get much flatter than that. Covered it up with some drop cloth and the wing just fits. Placed both wing sides on the table to check for proper base angles and matching joints. To my delight the joints matched up pretty good. Might be a little sanding at the base to make the seam even better but not much. Here's a few pictures of the wing on the table. I still need to do some more finish sanding and a dry fit on the wing joiner before gluing this together, hopefully get most of that done tomorrow and maybe glue it up this weekend.
ID:	400836   Click image for larger version
ID:	400837   Click image for larger version
ID:	400838   Click image for larger version
