Hi Barry,
Just so you don't overlook--When you consider wing loading you also have to consider size as well. A larger plane that has the same wing loading as the smaller plane will fly easier.
Reynolds Number
The factor that is called the Reynolds number was discovered by Osborne Reynolds of the University of Manchester in 1883. This parameter is important in wind tunnel experiments since it relates to the aerodynamic properties of lifting surfaces (like airfoils) when extrapolating from small wind tunnel test models to full-size wings. Reynolds discovered that, if the same atmospheric pressure were used for experiments with wind tunnel models as a full-size aircraft would encounter under actual conditions, the experimental results would be invalid.
In order for results obtained with a scale model in wind tunnel experiments to be valid, the Reynolds number needs to be the same under wind tunnel conditions and in regular atmospheric conditions. The way to ensure this is to increase the air density inside the tunnel by the same proportion as the model is smaller than the full-size aircraft. In practical terms, if a model is 1/10 the size of a full-size aircraft, then the air density (the number of atmospheres) inside the tunnel must be increased by a factor of 10 to get wind tunnel results that are valid in regular atmospheric conditions with a full-size aircraft.
Reynolds discovered the ratio that has since been called the Reynolds number when examining fluid flow characteristics-how a liquid flows in a pipe or how air flows across an aircraft wing. He demonstrated that the motion of a fluid may be either laminar (in smooth layers) or turbulent, and that the change from a laminar flow to a turbulent flow can happen suddenly. The transition from a smooth laminar flow to a turbulent flow always occurred when the ratio ?VD/µ was the same, where ? = density of the fluid, V = velocity, D = pipe diameter, and µ = fluid viscosity. This ratio is now known as the Reynolds number. The variable that can be adjusted inside a wind tunnel is ?-its density, and it would be adjusted by the same proportion as the model is smaller than the actual aircraft: a 1/10th model would produce valid results if the atmospheric pressure in the wind tunnel were increased by a factor of 10.
In actual subsonic flight, airfoils with low Reynolds number flows are laminar and those with high Reynolds number flows are mostly turbulent, keeping in mind that the Reynolds number is the ratio between density, velocity, diameter, and viscosity (For an airfoil in flight rather than in a wind tunnel, D would be the distance between the leading and trailing edge called the chord length along a flow.)
http://www.centennialofflight.gov/es...s_no/DI114.htm
