Threadlocker for plastic motor mounts
Anyone know what you can use for treadlocker on the glass-filled nylon (?) motor mounts from Great Planes and others? I tapped the mounts for 6-32 bolts and want to make sure they do not come loose. I recall Loktite will eat plastic. Can't really put a safety nut on the bottom as the mount is not flat there. Could have stopped the tap a little earlier to create sort of a Nylok effect but only thought of that after I tapped them!
Murray
