RCU Forums - View Single Post - screaming servos ?
Old 02-03-2006 | 08:57 AM
bhole74's Avatar
bhole74
Default RE: screaming servos ?
Another possible cause according to Hi-tec, servo case screws too tight. If it doesn't go away after the first few flight (as mentioned above) try loosening the screws in the bottom of the servo case 1/4 turn.
From the troubleshooting section on Hitec's web site:
Q. Servo hums under load
A. This can be normal, the servo is trying to hold position against the force of a load. If it hums when no load is applied, try loosening the servo case screws a quarter turn.
