RCU Forums - View Single Post - Transmitter adjustments while flying
Old 02-03-2006 | 09:12 AM
erbroens's Avatar
erbroens
Default RE: Transmitter adjustments while flying
It takes only 2 or 3 flights to set up a flap/elevator mixing in most planes... so it is safer to not
tinker with the tx software while flying... I also don“t recommend a knob switch for adjusting the mix, this is the kind of thing that works ok on ground, but can lead you to problems while you are
flying, concentrated on the plane.
Enrique
