RE: Transmitter adjustments while flying
Hi Jim
Why dont you use flight modes or flight phase. The mode swich can also be your flap swich. When in any mode all you have to do is trim the model with the trims. Your transmitter will remember the trim settings for each flight mode, and you can set a delay so that the transition is smooth. I use it like that on my Javelin
Paul
