ORIGINAL: Losmosis
Remember guys this is a huge truck and at the speeds it hits it can wonder because of the tire size.
If you suspension is setup soft it will make the truck wonder at speed also. Try stiffing up the back some to see if it helps.
You can add a swaybar also to keep things in check.
Other than that hang on it's one heck of a ride when this beast gets on the pipe...
William,
I noticed on your race setup sheets that you do list a 2.0 mm sway bar. Is there any way you could post pics of this set up or give us an idea on how you mounted them? Did you custom fab the sway bar itself?
