RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 02-03-2006 | 03:46 PM
  #335
mtracy
Default RE: Bdavison's E-flite Blade Assembly
During the step where you center the trims and set the sticks (collective down), is the transmitter in Normal Mode, or Idle Up Mode?
When set to Idle Up mode, the servo arms appear to be centered, but if I set the blades to 0 degrees here, when I am in Normal Mode, at down throttle, the blades are at a very steep angle, around 8 degrees. So when hovering, the helicopter is basically flying at a stall. What's the proper way to set the blade angle? Thanks,
