RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 02-03-2006 | 04:17 PM
  #336
catfight
Default RE: Bdavison's E-flite Blade Assembly
mtracey,
To set blade level to 0, you must be in idle-up mode (idle-up switch towards you), all trims centered and stick at mid position. You then set the blades level with the flybar (the angle anyway).
