RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 02-03-2006 | 06:01 PM
  #341
mtracy
Default RE: Bdavison's E-flite Blade Assembly
Well, something is not right. Some seem to say center all sticks and trims, then set the blades to 0 degrees, while others say throttle trim down, stick centered, and another says trim centered, stick down! I guess everybody has there own way of doing this.
BTW, when I have everything centered, and try to set blades to 0 degrees, I run out of adjustment turns on the rods. And I have checked that my swashplate top is 1/2" from the top of the main shaft. Thanks.
