RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 02-03-2006 | 06:04 PM
  #2078
duaneh1
Default RE: E-FLIGHT BLADE CP
ORIGINAL: zooland1
[quote} It's fully possible there's something wrong with the 4-in-1 or TX. Another thing to check would be the antenna wire. How is it wrapped, rewrap it and see if that helps. I put it inside an antenna tube so it can't contact any CF. Next step would be a call to Horizon.
Thanks zooland, I called horizon-the dude doesen't know much-thinks it is mechanics-I don't think that's the cause but will doublecheck. Antenna is in original location, will reroute with tube that I have. I do get glitches indoors only in nose-in hovers which i guess is caused by the way I'm pointng my transmitter antenna. I was afraid it was issue with tx or rx. I will try disengaging motor from main gear so i can run it without spinning the blades and if determine if blade pitch changes without changing throttle. Will that be hard on the motor-running with no load? How do you get Horizon to replace parts-do you raise hell with them?
