RE: Air Hogs Aero Ace!
On my AA i have a few little problems and i wanted to see if you have any suggestions to help. My first problem is that it is always turning to the left a little even though i adjusted the tail of it. it's not to bad but it is a little irritating having it always turn to the right or left a little and sometimes if im lucky have it go straight for a while.but when it goes straight when it flies for a little it starts turning again when it's over my house.Any suggestions?Another problem is starting to worry me because real bad stuff could happen when i fly like 50 feet away. The problem is that after i get about 2 or 3 houses away from mine or like 50 feet it totaly screws up. The plane signals don't reach the plane right even though the box says it has a 300 foot range. I mean i could stand where i am with it sitting on the ground because the signals screwed up and i will hit the throttle on full and nothing happens until 2 seconds later. It's sorta like a sattlite tv signal compared to a cable tv where the picture is like 2 seconds later than the cable tv. If i tried to solve this would an unbent metal coat hanger wraped around the antenna do anything to help? Please help people.
will
_______________________
We are all just bugs on the
winshield of the car of life.
