ORIGINAL: avalanche wolf
I gave the pitch controll on the fly bar 3 half turns and we have lift off. I think i am going to give it another 1/2 turn and it should be about normal.
Although now i need to redo my rudder mixing since it is going nose right took 3/4 trim to keep it stright.
I'm glad to hear you can at least get off the ground, but still curious about the limited movement. In idle up, mine nearly touches the lock ring at full throttle and actually pushes the head to the limit on negative. Close to 1/2" travel end to end. I don't see 1/4" on yours. In normal mode are you now at zero pitch with no throttle? I'd guess you're about 5 degrees, which is what it takes to lift off. Then when the head speed gets high enough you get lift. Hopefully I'm wrong, if not your 4-in-1 is not sending the right signals to your servos.
