RE: E-FLIGHT BLADE CP
motorsports,
I use double-sided foam tape that comes on a roll from local walmart. The partiicular brand I chose was "Duck" and is about 19mm wide x 2mm thick and works fine - just make sure you add tie wraps to strap all servos in.
Cheers
