RCU Forums - View Single Post - split elevator,two servos?
Old 11-29-2002 | 06:59 PM
Geistware
My Feedback: (16)
Default split elevator,two servos?
You can also try one Hitec and one Futaba servo. The rotate in opposite directions. If the speed is the same (or close) you should be OK.
Originally posted by Eindecker
Hi,
Thanks guys,ive just discovered that my tranny is not able to mix two servos for elevator,so it looks like i will have to go for the y connector with servo reversing,is it possible to make sure they travel at the same rate,or will the reverser take that into account,from what i can gather as a newbie,does this mean i must find two servos that are travelling at the same speed,or very near to each other?
Your input always welcome
Cheers
Eindecker
