RE: Do 2-stroke engines run clockwise
I think you have been told a bunch of correct but confusing stuff. All you need to do is put a pusher prop on it. Pusher props are made to push rather than pull when running in the usual direction. Unfortunately, there are not as many sizes of pusher props as there are of tractor props. 10 x 6 pusher props are fairly common, however.
