Control horn problems
I am putting together my new 300 special and I've discovered one of the pre-drilled holes for the aileron control horns was drilled at an angle. The result is the screw on connector to the pushrod is about .165" shorter than the other aileron and the horn & connector are at an angle pointing down towards the wing. The pushrod assembly is not in a straight line like the other wing, kind of looks like a kink in the system.
1. Has anyone else had this problem
2. Is this worth worring about
3. If I need to fix it what would be the best way
Bill
