RE: Installing a new ring?
Bill:
If the 4500 is one of the STs with the ring's pin notch offset from the ring gap, be sure you have not installed the ring wrong side up. When installed correctly the gap is always riding on the sleeve, and does not cross any of the ports.
Memory says the gap should be counterclockwise a small amount from the pin, when looking from the top.
Bill.
