RCU Forums - View Single Post - Custom Headers/need help
Old 02-04-2006 | 06:10 PM
flybye Steve
Default Custom Headers/need help
Hey guys, I'm working on a new TOC 1 Extra 330-42% and have serious exhaust problem.
The stock mufflers for the DA 150 will not fit without carving up the motor box. Also, I'm affraid the stock mufflers will not provide required db level for my field.
The plane is not set up for canisters but I can fit them in.
The problem is that the centerline of the canister is 5.562" below the exhaust manifold and there are no standard headers that will accomadate that much of a drop. Also besides the drop, the only possible canister location requires an offset built into each header.
I have puchased bits and pieces of parts from DA to make up a header however, the tubing (28mm) requires bending fitting and silver soldiered joints.
This is truly specialized work if proffesional looking results are to be expected. Also I have contructed a proffesinally designed and built fixture to insure alignment and fitting.
I have not been able to find an exhaust system manufacturer who will make a custom header and this is not the kind of work most machine shops are capable of doing. Especially with metric size tubing.
Any ideas greatfully accepted.
