RE: Reaction 54 Jet Kit
Hi Dave,
I figured out my 9cap radio problem. I had to exchange it for a new one. The transmitter wasn't transmitting. Just my luck. The new one is really nice though. A little different than what I have been using. When going thru the start up procedures for the jetcat, the "idle" position is max. throttle trim. Is that above the center point and clear to the top? (The trim adj. is a little different on this Futaba than I'm used to. ) Then when I go max. throttle,to start ignition, and drop the stick to idle, the light won't turn green unless I drop the trim on this new radio to neutral. Is that sound right?
Steve
