RCU Forums - View Single Post - Gas Engine Throttle Servo Placement
Old 02-04-2006 | 11:13 PM
Geistware
My Feedback: (16)
Default RE: Gas Engine Throttle Servo Placement
The ideal condition is to keep the two electronic systems at least 12 inches apart.
I have had battery packs for ignition and receiver on top of each other seperated by a 1/8 inch piece of foam. It all depends on how good your ignition system is. Low noise and good ground will allow you to do this. ANY noise will cause a problem. To be safe the more distance the better.
