RCU Forums - View Single Post - Multiplex and receivers..
Old 02-05-2006 | 06:27 AM
Falcon 64's Avatar
Falcon 64
Default RE: Multiplex and receivers..
ORIGINAL: HarryC
ORIGINAL: Gudmund Malones
Anyone using their MPX 4000 TX with a different brand of RX in PCM mode?
That is not possible Gudmund. Each brand uses its own version of PCM code, so you can not mix brands in PCM like you can with PPM. Only a Multiplex PCM receiver will work with the 4000. The Multiplex PCM had not been updated and is slow and of low resolution compared to modern PCM in other brands. It really is time for you to move on to IPD!
Harry
I`ve had IPD since the day it became available..
I now have four 12 ch IPD receivers..
Gudmund
