RE: OS .25 and .46 problems
Doing good so far, prop sizes are in the right range and mufflers and pressure are being used. The next thing I'm wondering is how you define running hot? All engines run "hot". Is your assessment of hot based on a comparison to other engines, or just that they feel hot when you're finished running them?
You said richening the engine doesn't make any difference. Is it possible that you've got the needle set too rich? How many turns out is the needle? Have you tried setting it leaner?
Typically what you should do is start with the manufacturer's suggested setting. For most engines, this will be too rich. Once you get the engine running you want to gradually lean it until it's on the slightly rich side of peak RPMs. The way to determine this setting is to gradually screw in the needle. The engine will get faster and faster, but then will begin to slow. When it begins to slow, you've gone past the peak setting. Immediately screw the needle back out through peak to the somewhat rich side.
Note, you should not set the engine so close to lean when you're breaking it in. Also, the setting I described above is not ready for flying, it's just for running the engine on the ground or on the bench. To confirm the high speed needle is set appropriate for flight, you need to hold the plane firmly with two hands and have someone else run the throttle up to full speed. Once it's at a steady speed, point the nose of the plane straight up. If the engine slows down, it's too lean. Lower it and set it richer and try again. If the engine stays at about the same speed, it's also too lean. If the engine speeds up a little and holds this speed, it's probably about right. If it speeds up significantly, it can probably be set a bit leaner.
While doing the above, you should NEVER try to adjust the needle while you're holding the plane in the air. You also should never run the engine up, or adjust the needle while you are in front of, or beside, the prop arc. Engine adjustments should ONLY be made while behind the engine and with the airplane firmly secured.
