RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 02-05-2006 | 12:32 PM
  #2103
1LO64
Default RE: E-FLIGHT BLADE CP
ORIGINAL: catfight
1lo64,
I used 2 on each blade installed between o-rings and stepped washer. Eventually had to add 2 more after spindle stretched and o-rings wore down :0)
Cheers
Thanks for the quick response......So you install them in-between the o-ring and stepped washer? Shouldn't the washers go behind the stepped washer??
