ORIGINAL: Super D
I moved my flybar weights all the way and it was more responsive. Today I took them completely off, which is even more responsive. Now if I can get the bell-hiller I may try some inverted stuff. OH and BTW my LHS said Horizon is now supposed to have the B/H system in stock very soon?
Has anyone tried to autorotate the blade? I doubt it would work since the motor would have to turn as well. Just curious if the blades will even turn and possibly lessen a crash.
I bought the HB CP2 head from heli-hobby, had to buy the parts separate and they're plastic, buy hey for 20 bucks I thought it was worth a shot. Haven't put it on yet, sorry I can't report how it works. The reason I bpought the autorotation gear was the shaft upgrade. It has a much harder shaft than the stock one and is very easy to change out if you do happen to bend it. You don't have to tear down the whole frame to change the shaft. Just pull a pin, change the shaft, put the pin back in. Don't know if the autorotation works properly or not. Never flew a bigger bird to know what it's supposed to do. I just thought the gear was cool.
